my god ! 4 roue en avant ! jaimerai esseyer ca pour sentir la conduite !
il me semble, plus de roue, plus de traction, plus de freinage ?
ENGINE: rear, longitudinal, 8 cylinder in V formation, 4 valves per cylinder, naturally aspirated, petrol direct injection Bosch-motronic. CAPACITY: 4200 cc MAX POWER: 440 PS (325KW) at 6400 rpm MAX TORQUE: about 470 Nm at 2700 rpm TRANSMISSION: rear wheel drive transaxle GEARBOX: mechanical 6-speed + reverse. Manual and electro-hydraulic steeringwheel mounted servo CHASSIS: steel tubular with carbon fibre reinforcements and structural parts SUSPENSION: independent front and rear wishbones WHEELS AND TYRES: front 15in wheels with 205/45-15 tyres; rear 20in with 345/25-20 tyres BRAKES: front and rear vented Brembo discs. Bosch servo and electronic brake distribution BODYWORK: glass fibre and carbon fibre DIMENSIONS: length 4180mm; width 1990mm; height 1080mm; wheelbase 2230mm/2750mm (to foremost/middle front transaxle); front track 1540mm; rear track 1620mm ; dry weight 1150Kg TOP SPEED: 300Kph (185mph)
DragonEye.Monchar.Com "This is what happens when an unstoppable force meets an immovable object."
