New Paintjob - Rust repair - Amazing results !!
95exrv6
Post by 95exrv6 »
I love my car.
It was time she got some paint repair cause the rust was bad.
I have been waiting for my car to be completed.
I have access to another car so it was urgently needed in 1 week or 2 weeks.
I wanted to give them enough time to give quality work.
The bodyshop I work with arranged to do the work on lost time.
They do not do 1/2 ass work. They spray cars for dealerships and have a downdraft paint booth !!! ( allows them to bake the cars and have roof mounted filters - Great setup !! )
It worked out really well.
The paint is a Mid quality. Dupont Cromabase, with added metalic.
5 Base coats. 3 layers of Dupont CromaClearcoat.
They needed to cut both my rear wheel arches out and re-weld the whole section on both sides. It was very rotten on the passenger side. My undercarriage needed to be repaired in certain areas (lift points, toe hooks, rocker panels) Whole car on the outside got sanded down and repaired where needed.
They used great materials and together have over 40 years of bodywork experience.
I ordered new wheel arches, for the Accord 94-97.
According to the body parts depot, they sent the right ones, which was not the case. They sent 92-95 Civic skins. They were used anyways, with lots of extra welding, cutting, modifying to fit.
my car at the dealership, before I bought it in 2001 ( look at the wheel gap )
driver side wheel arch welded on
passenger wheel arch side rotted out
misc bodywork performed
finishing passes
tested color on inside of repaired passenger wheel arch
more ...
Other rides
10 Odyssey
04 Civic LX - scrapped
93 Civic SI - Projet
95 Accord V6 Manual - sold
96 Accord EX - sold
98 Odyssey EX - sold
92 Accord EX - scrapped
92 Civic EX - scrapped
95exrv6
Re: New Paintjob - Rust repair - Amazing results !!
Post by 95exrv6 »
the end product - painted
the original in the door pillar with original color. Look at the difference !!
shots taken today in my driveway
What ya think?
Shaved antenna
rust repair
full paintjob
Other rides
10 Odyssey
96 Accord EX - sold
Post by carotman »
Ça semble vraiment bien fait!
Fini la rouille pour un bout. N'oublie pas de la faire traiter à l'antirouille.
Combien ça a couté?
grosse job man, je suis pas seul à capoter sur la rouille c'est bien ca! en parlant de rouille je vais avoir ma carte de Rust-Killer yea! yea!
95exrv6
Post by 95exrv6 »
carotman wrote:Ça semble vraiment bien fait!
Combien ça a couté?
I did get it rustproofed as well. They did it with
In the spring it's getting a full compound. Did not want to do it now, no point with winter and salt, rocks etc ...
in total, the whole service, including the best interior wash I've ever seen in my life, rustproofing, engine bay cleaning ... 3700$
Remember, just the Dupont paint kit was 700-800$
They did 100 hours on the car, so it was 30-35$ an hour.
5 basecoat passes
3 clear coat passes
All done in a downdraft paintbooth system
Anyone looking for paintwork, and wants real quality, let me know
I'll arrange something you can not refuse.
parent wrote:grosse job man, je suis pas seul à capoter sur la rouille c'est bien ca! en parlant de rouille je vais avoir ma carte de Rust-Killer yea! yea!
Rust sucks, but I'm gonna be ok for a few years now ;)
Please Rust Treat all your cars, even the beaters ...
Other rides
10 Odyssey
96 Accord EX - sold
Post by DragonEye »
wow ! amazing paint job !
dupont = best :god: waterborn pain or chromabase ?
5coat of base look for me useless, since dupont cover enough... (except if you run a setup without sealer before paint)
congrats !! :beer:
(the only thing i could be again, its the stove pipe :)
Post by accord h22 95 »
wow une tres belle difference ,faut que jfasse peinturer la mienne aussi l'annee prochaine
Tu a mis 5 couches de basse ?
Post by mollyboy »
parent wrote:Tu a mis 5 couches de basse ?
Ça arrive , Jai déjà vu un char a 8 couche ! Ça dépend de la couleur de la peinture , celle en dessous et de la peinture tout court!
Post by DragonEye »
un brin useless 8 couche de base (depend du peintre) parce que 1couche de fond + 2couche wet, ca fait amplement la job...
a place de metre 5 couche de base, j'aurais mis un sealer noir, 2 couche de base wet, avec 4couche de clear chroma pour le meme prix....
du base cest de la couleur.... quand meme que tu en met 10couche, la peinture sera pas plus belle... il va seulement avoir plus de possibilité davoir des grain.... une fois que ta couleur es matché et que ton metalisé es egal... tu shoot le clear
ah, et avant que quelqu'un pence que je dis n'importe quoi, je travail carrosier chez bellemare longpré de jour
et chez carroserie sylvain charette (custom/antique/hotrod et moto) comme peintre le soir et les fds
(le meme garage qui as fait la job sur la LEXUS a stuntg)
de toute facon, belle job quand meme :tu:
Post by mollyboy »
Mais plus ta de couche aussi , peinture et clear , plus ça va être solide et resister au eraflure!
Pas faire comme les nouveau honda et tombé sur le primer a la moindre chose :encliff:
Post by DragonEye »
mollyboy wrote:Mais plus ta de couche aussi , peinture et clear , plus ça va être solide et resister au eraflure!
pas exactement, si tu pogne une grafigne, la protection de la peinture es le clear... si tu as 2couche de clear (oem) elle va etre buffable et voila le travail !
si tu met 4+ couche de clear, tu peu sabler les gain, et tu peu buffer le clear presque a volonté sans avoir peur de passer au travers quand il y a une graffigne...
du base coat cest pas fait pour etre endurant (a moin dun base qui as ete catalysé) et es fragile (grafigne avec un ongle)
comme jai dis plus haut, cest de la couleur, rien d'autre.
si tu as 8 couche de base... tu as plus de chance justement que ta grafigne depasse le clear et ateingne ton base
peu importe si une grafigne se rend au base, primer ou metal, il faut resabler et repeinturer....
dans les usine qui fablique les autos neuves ; 1couche de sealer, 1 couche de base a l'eau, 2couche de clear.
sorry pour la polution de topic....
tres beau travail :god:
Ont parle de peinture ont est dans topic encore hehe. C'est fun dans savoir plus car moi le monde me dise de faire ca de tel façon et 20min aprêt un autre me dis le contraire ''à ma job''
Ont fait de la peinture, compound toute se qui comporte l'esthétique automobile. Puis quand vien temp de faire une job de qualiter qui va duré plus que 5 ans sa c'est pas quoi dire fake en gros j'ai plus confiance au CAQ que monde avec qui je travaille. Encore hier mon beau pére me dis pour quoi tu prend pas du décapant à peinture, just pour vous dire que sa contredis à tour de bras. Aprêt avoir sablé durant 14hrs je sais toujours pas quoi faire....
Post by mollyboy »
parent wrote:Ont parle de peinture ont est dans topic encore hehe. C'est fun dans savoir plus car moi le monde me dise de faire ca de tel façon et 20min aprêt un autre me dis le contraire ''à ma job''
ça , y'a rien de mieux que de tout ramener sur le métal et de recommencer a neuf!
mikeb
Post by mikeb »
je te le conseille vraiment pas! sauf ou il y a de la rouille c'est sur , sinon tu fait rienque sabler le clear au 500 et etirer ta peinture pour les correction graffigne, pico etc... sinon la peinture risque de caller a ses endroit, le secret et faire des beau nuage et que tu sente auqune coche en passant ta main faut ca soi doux comme des fesse de bébé!
Accord h22 91
Volvo 850 Turbo 94
Regal 3.8L 92
KX 125
95exrv6
Post by 95exrv6 »
DragonEye wrote:wow ! amazing paint job !
congrats !! :beer:
Chromabase
Primiere would have been 900$ per quart (used almost 4 full quarts)
these guys did 5 coats and 3 clears because that is what it took to get this result. They have been painting for 40+ years together and they paint showcars bikes, snowmobiles, all the time.
I did not want a shitty paintjob that will chip easy. With 5 coats of base, and 3 clears, the surface is very hard and more solid, but that is also becuase they have a downdraft paintshop, so it really help to 'bake' then paint at 120C.It also gives me the chance to polish the paint less because the passes of paint are soo good ;)
All I have to say if they gave me a warranty on the bodywork and paint as well
Very Satisfied.
All bodyshop/bodymen have their own techniques.
This is what they did. ;)
The other reason why they did 5 base coats is because they mixed in more metalic into the paint then original. A lot more.
Normally the Bourdeux Rouge gets 10 grams per quart in the mixture.
They added another 40 grams
Other rides
10 Odyssey
96 Accord EX - sold
il parlait de ma job, restoration du frame.
max1102
Post by max1102 »
XXX2 tu as absolument raison, le nombre de couche de base c'est seulement pour rendre la peinture uniforme. le clear fait toute la différence en se qui concerne le fini. L'année derniere quand jai fait shooter mon char mon frere a mis que une couche d'appret, 3 couche de base et 4 couche de clear. Cette année vu que je change de couleur, je vais mettre une couche d'apres, 3 couche de silver, un couche de lian avec perle ou p-e 2 afin de uniformiser le tout et finir avec 3couche de clear, sablé a l'eau et en rajouter 2. Qu'est ce que t'en pense de la formule base et apres lian pour le perle parce que c'est la premiere fois que je vais utiliser cela :????:
la différence entre le pouce et le majeur? essaie de faire du pouce avec le majeur
Post by carotman »
congrats !! :beer:
Chromabase
Very Satisfied.
Nice :D So, what's this shop? The price seems very decent for the amount of work they did!
95exrv6
Post by 95exrv6 »
JB Auto
They are located in Carignan on chemin Chambly.
They've just setup the new bodyshop.
Interior Cleaning
Car Wash
Painting
Waxing / Compound
Frame work
Accident repair
The team there works amazing.
Free Estimates on work
If anyone is interested, pm me when you want to go there.
Other rides
10 Odyssey
96 Accord EX - sold
