civic RWD
civic RWD
Post by mollyboy »
This Honda has an Acura Legend V6 3.2liter in it, plus a 16g turbo and front mounted intercooler. The car is also rear wheel drive and has side pipes for the exhaust; 5 spd trans axle in the rear of the car. The car weighs 2600 pounds with 53% of the weight in the rear. You can not believe how hard this car pulls. V6 engines have a tremendous amount of torqe, plus, you add a turbo and you have over 400lbs. Because the weight is in the rear this car hooks up hard. I drive the car everyday to work which is 60 miles a day. You can't believe how well the car rides and sounds. It does not sound like any other Honda out there. This is like a V6 Camaro and adding a big block in it. If you like sleepers, this is the car.
This is the only Honda Civic that can be used in drifting competitions.
Drawing big crowds at car shows and at competitions and getting sponsorship should not be a problem; if that's what you want to do with it. Me, I just like to drive the car.
The interior is completely redone from the carpet to the headliner. It is all custom to match the driver FX racing seat in the front. You can't tell from inside the car what is under the hood except for the raised floor tunnel (4 inches). Even the trunk has been upholestered to match.
Pioneer head unit with cd and an Audobon amp and 16x9 and 6.5 speakers stereo system.
exterior: custom paint job, but not too loud. Normal body kit with the exhaust coming out of both sides in the side skirts; projector head lights and carbon fiber rear lenses; rain and side moldings have been shaved; paint is very good; no dents or scratches.
Post by Delowan »
Le body kit/mags/lumières, fitent pas avec le moteur et la conversion RWD...
Mais ya dla job là dedans.
Post by HAccord »
:roll: pas sur qu'on a la meme definition de sleeper....
mais ca doit etre le fun en maudit a chauffer une ptite civic dememe!!
Post by DragonEye »
wow :eek: :malade: :drool: on a la preuve que tout es possible :god:
Post by Addickted »
c'est pas petit un 16G pour la grosseur du moteur?
Post by JasAirbrush »
Dans un sens ca peut être sleeper.. a première vu on s'attendrais a un moteur stock turbo ou au pus un gsr turbo.. pas un v6 turbo!!
Honda JDM
Post by Honda JDM »
il est tous simplement fou sérieux , une civic comme sa sa doit faire de la drift incroyable :gne: :pifpaf:
MR. F20b! Image
ACCORD 92' LX 4 DR---Mort
ACCORD 92' EX-R 2 DR---Mort
ACCORD 93' EX-R 2 DR---mort
----CR-V 02' EX AWD---Survi
ACCORD 93' LX 2 DR---hiberne
ACCORD 92' EX-R 2 DR---daily drive
Post by HAccord »
c'est vrai que c'est pas...commun :confused:
Post by mollyboy »
n'empèche que j'paierais pour essayer c'te MONSTRE la!
Post by Delowan »
mollyboy wrote:n'empèche que j'paierais pour essayer c'te MONSTRE la!
bof j'aimerais mieux n'importe quel char RWD d'origine que ca...
Post by TitaniumACC »
mettons que y'aurait pu prendre une base plus belle que la civic sedan 92-95.. J'avoue que le style du char fitte pas trop trop..
J'aime mieux la civic de drag RWD de Napi qui était au CarFever...
Post by DragonEye »
ou je pourais avoir des info sur ste monstre la et le cheminement ?
dislexi
Post by dislexi »
serieux ya vrm de largent a depenser ste gar la pour ca, ca du lui couter deux jambes avec boni deux bras :malade: mais javou que ca doit etre malade voir ca dns un evenement de drift ou assis a coter :confused:
a quand mon prochain cb7
Post by michael_ »
trop malade :tu:
